Wanted a sanity check before I go cutting stuff. I currently have 6" of lift and 37s. I want to get the most up travel possible but currently at full stuff I rub the inner wheel wells.
I don't want to lose any up travel. Here is where it rubs when flexed similar to the pic above. The green area has already been removed this was just an older pic. The red area is where it currently rubs.
Once I relocate the air box/battery can I just start removing the inner well or will it make it too weak?
The other rub area is the pinch seam. Anything that gets removed I would rebuild with 16 or 18g sheet metal. I know TNT makes a replacement panel but again I just want to make sure I'm doing this right before starting.
Any tips? Best practices?
Do I need a spot welder or can I do it with my mig welder?
