Modified Tech Discussion Forum for Tech related discussion for Modified XJ's and MJ's. |
Thread Tools | Display Modes |
waggy 44 and rubicon style radius arm
does any one here use this setup with around 7" of lift my concern is with being low pinion but it works on the tj with low pinion 30 im sick of the stupid unit bearings and i already have the waggy axle so this would get me back on the road with less downtime than narrowing the ford hp or going fullwith
#2
Re: waggy 44 and rubicon style radius arm
rotate the knuckles for proper pinion and caster angles and you will be fine. however if you have a Ford HP available, go that route. Narrowing an axle is only a tiny bit more work than turning the knuckles.
Thread Tools | |
Display Modes | |
Old Style to New Style Gear Shifter Write Up | BIGSLVRXJ | OEM Tech Discussion | 0 | May 6th, 2005 19:39 |
Factory style towhook brackets and newer style cooling fan | joe88xj | For Sale: Private Party Only. XJ ITEMS ONLY | 8 | November 23rd, 2004 02:13 |
JKS Shock Adapter XJ style vs TJ style | pfogle | Modified Tech Discussion | 1 | May 31st, 2004 21:50 |
RE YJ Radius Arm | dennisuello | Modified Tech Discussion | 9 | May 4th, 2004 19:13 |
Converting stud-style to eye-style | Fergie | Modified Tech Discussion | 24 | June 12th, 2003 16:44 |
