Old September 3rd, 2011, 19:58
Explorer 1 Explorer 1 is offline
Question on mounting Bilstein 7100's
It Saturday and because it's a three day weekend it will probably be Tuesday before anyone at Bilstein will be answering their phone to get anm answer. You guys have always been a good source of information in the past.
I'm installing Bilstein 7100 shocks in the front of my 90 XJ. Because the shock mount area is so narrow I can't place the upper shock mounting eye as I would normally, that being parallel to the front bumper or perpendicular to the side of the vehicle.
Both ends of the shock have a Heim joint that allows forward and back movement of the upper shock as I have mounted it.
The lower shock is mounted in the usual way, parallel to the front bumper.
Any harm in how I installed it?
Thanks for you help......
Fred
Explorer 1
Old September 3rd, 2011, 20:22
xcm xcm is offline
Re: Question on mounting Bilstein 7100's
you be fine unless you are completely bombing the whoops all day long, or have CRAZY flex/travel. those heims will handle the misalignment. i usually tuck the reservoir more away from the tire, as if in rear of the shock as opposed to the side,but im not sure it would hit anyways.
Old September 3rd, 2011, 20:35
Darky's Avatar
Darky Darky is offline
Mine are mounted facing rearwards.
Old September 3rd, 2011, 23:29
dirtweazle's Avatar
dirtweazle dirtweazle is offline
You should not be able to grab body and move back and forth. they make spacers you will need to trim that fit between mount and heim to take up any space.. Also move rez to the back or front of the shock body.
Like this:
Old September 4th, 2011, 07:43
RandomThoughtsRace RandomThoughtsRace is offline
Perhaps the upper stem /eye conversion mount can be rotated to 45* and the reservoir can be further rotated around the shock body to tuck it away niceley. Also, if you loosen the hose clamps and twist the reservoir the hose will begin to twist a bit to help keep it from rubbing on the inner fender.
Fred
Explorer 1
Old September 4th, 2011, 19:04
xcm xcm is offline
or a peice of rubber hose split down the middle, with a couple zip ties... that stainless braid will file thru sheet metal if left vibrating long enough.
also, hope you waxed them 7100's, they sure is purdy!
bilstein 7100's $250 obo!!!!!!!!! livinthedream SoCal For Sale 3 March 8th, 2011 18:17
Anyone got a hookup on bilstein 7100's? boostamante SoCal Chapter 10 October 19th, 2010 11:56
bilstein 7100's for trade clean4drxj NAC Classifieds 8 October 18th, 2010 07:29
FS- Bilstein 7100's Andy in Pa. NAC Classifieds 5 June 8th, 2009 08:44
Fox Shox vs. Bilstein 7100's bbaker80 Modified Tech Discussion 12 June 28th, 2003 17:32
