Old September 13th, 2020, 07:08
whitexj98 whitexj98 is offline
Mandrel Bent SS downpipe
I'm redoing my exhaust front to back, stumbled across this place out of New Jersey, UPSW Auto Parts selling a mandrel bent Stainless Steel down pipe. They come from China under the name Northeastern Exhaust.. ordered it up and sure enough it's real. Haven't installed yet as I'm still waiting on other parts but figured I would pass along. I have never seen a mandrel bent downpipe available, let alone SS. If you can't find it on their website they sell on eBay also.
Old September 13th, 2020, 07:55
RCP Phx RCP Phx is offline
Re: Mandrel Bent SS downpipe
The downside is they are stock in size and they don't use the right grade of SS (besides their minimum selection).
Old September 13th, 2020, 10:59
maxbraketorque maxbraketorque is offline
Yep, 409/410 SS is commonly used on OEM exhaust systems. Better than carbon steel, but not nearly the same as 304 SS.
Old September 13th, 2020, 11:09
Anak's Avatar
Anak Anak is offline
Stranger
Still nice to know the option exists.
I am happy with the stainless tail pipe I got off ebay.
I am bummed the Borla 17039 stainless header/downpipe is no longer available. Having options is good.
Old September 13th, 2020, 12:14
Agreen Agreen is offline
It's nice to not have the "we totally did this to clear the axle, but in reality it's probably for emissions" exhaust kink though.
Old September 14th, 2020, 08:10
4x4JeePmaNthINg's Avatar
4x4JeePmaNthINg 4x4JeePmaNthINg is offline
Are you welding this to the stock exhaust pipe or is stock carbon?
Old September 14th, 2020, 21:23
Evan03 Evan03 is offline
Its very low stainless content itl weld fine with anything handy.
Old September 18th, 2020, 18:38
OBXJeepGuy OBXJeepGuy is offline
Any part number for this? I couldn’t find it in their website. I’m probably wasting my time, as this also won’t fit a Renix 4.0.
Old September 18th, 2020, 22:33
305108
At least that's what they list on their eBay page. I didn't see it on their website either. I went back and searched that number and got a Civic muffler?
https://www.ebay.com/itm/Stainless-S...AOSwqR5eOI~ n
I don't have any data on whether it fits a Renix XJ or not.
Old September 19th, 2020, 04:58
Awesome. Thanks for the info!
Old September 19th, 2020, 06:25
Youl need the ho exhaust manifold to go with it
Old September 19th, 2020, 06:47
Old September 19th, 2020, 14:32
jeepingben jeepingben is offline
Mine arrived on Thursday
The flange that mates it to the manifold is much bigger + is not quite the same. The restrictive dent is gone though.
The locking flange nuts I was using before aren't compatible. I don't thing regular hex spring locknuts will work either. It almost needs a conical nut or at least a small thick washer.
I was not able to get a good seal to the manifold yet. I will try different nuts and hopefully more even pressure will let it seal.
Old September 19th, 2020, 19:50
Anak's Avatar
Stranger
Well that isn't right.
Bummer.
Simplest solution is probably going to be a thick washer, and you will need to grind one side of it.
I would be inclined to tack weld the washers to the flange.
Old September 19th, 2020, 22:58
Ralph77 Ralph77 is online now
Did the same thing.
Put a whole new exhaust in my '00. An '00 is mostly flanges.
Bought a bunch of stainless steel nuts, bolts, washers, etc for the job.
In a place or two the washer would not lay flat in the flange.
I just ground down the side so it would.
Mandrel Bent Downpipes? JoeyBottles Modified Tech Discussion 13 March 31st, 2014 17:51
mandrel downpipe? wannabe Modified Tech Discussion 8 January 13th, 2007 19:23
Where to get a mandrel-bent 2-1/2" XJ tailpipe? hawk_sixsix Jeep Street and Performance 17 December 10th, 2006 18:37
