View Single Post
  #3
Old April 16th, 2005, 10:47
Yucca-Man's Avatar
Yucca-Man Yucca-Man is offline
NAXJA Member # 683
Re: replacing fuel filter
Make sure you put it in facing the correct direction as well. A cap on the end of the old one as you remove it will help keep gas from pouring down your arm. Depressurize the fuel rail with a small (non-sparking preferred) screwdriver or dowel while holding a rag over the fitting to prevent drippage. Enjoy.
