View Single Post
  #10
Old June 8th, 2019, 07:53
Hurricane06 Hurricane06 is offline
Re: Track bar frame mount
Thanks for all the feed back Gents. I was able to get the cotter pin out. I then put it on a drill press to drill out the bolt. I got 1/4 bit through the bolt, then decided to try and get the nut off. Low and behold with less bolt there was less pressure and the nut let loose. Then put it on a vice and used a c-clamp with a socket to get the pressed in bolt out. Success!!! Took it to the sand blaster and cleaned up all the rust. Painted and re-installed it.
http://https://photos.app.goo.gl/iYL77G5C7gCqp2eb9
