I'm having a very strange problem and after searching around I have found no one that seems to have related problems
If I'm cruising coming up to a traffic light, and it changed suddenly and I brake hard, while coming to a stop the Jeep seems to downshift itself into neutral for a moment. Then once I come to a full stop it shifts back into drive. I can feel the lurch forward when it happens
Or another example. If I slowed down for the same situation. But then the light turned green and I let off the brake just before coming to a full stop, when i go for the gas it just revs, and then you can feel the shift into drive and then it operates completely normal
120k on the clock. I got the Jeep some years back and planned on doing a fluid and filter swap this coming year. The reason I haven't done it sooner is because I dont know what the PO used fluid wise when they last did the service
