- Virginia City, NV
I though rather than starting new threads all the time, to ask questions of the local knowledge base, I'd just start a build blog thingy. So here goes.
I bought the gorrilla for well nothing. I traded a crappy guitar for it really. It had not been well cared for and had a blown head gasket and a cracked head. A few solenoids out in the trans and had been roughed up a bit by other cars. In the long run after finding low oil pressure I swapped in a 92 motor and took it wheeling. I had most of the suspension bits and tires laying around from another jeep. Threw it together and started actually wheeling it about 1.5 years ago.
Current specs
97 2Door Auto 231 White
Engine Stuff
92 Motor ~165k on it
thor cowl intake
99 intake
tube exhaust header
stock cat
super 40 with a turndown
Front end
3.5" re springs
Extended bumpstops with one hockypuck on the pads
12" doetsch shocks Very stiff
RE 1600 trackbar
Currie Steering over the knuck on the driver side
No Sway Bar
2" Wheel Spacer
Dana 30
Stock Shafts 760 ujoints
stock 4.10 gears
Stock brakes
chevy brake lines
third hand used Lockrite
RE Drop brackets w/ braces
RE adjustable uppers
RE Solid Lowers
Rear end
Dodge Van 1ton Bastard Pack
Shackle Relocation boxes
IronMan4x4 adjustable shackles
12" Doetsch Shocks Very Stiff
Cross Enterprises shock hoop
durango center brakeline
Explorer 8.8
Stock Disks
stock 4.10 gears
LSD diff repacked tight with carbon disks
1.5" wheel spacers
extended bumpstops
Leaf plate bump pads
Body
C-ROK4X4 Rear bumper and Tire Carrier
JCR gas tank skid
rigidco front bumper
timken rocksliders welded
35" bfg all terrains
Stock Eccos Wheels
Here are a few pics from its first year of wheeling (and mine haha)
So had some issues at RenoFest.
Trackbar bushin was fubar at only 300 miles.
Bent a read drive shaft.
Broke the passenger inner shaft on the d30.
So I have a few issues I need to address before Sierrafest.
I desided to go ahead and regear to 4.88s and rebuild the front diff. Then Lincoln the rear(short term). I'll be pulling these axles this winter so they will be gone through again and will be getting a rear locker at that point.
Also going to replace the heim on the track bar and control arm bushings.
Oh yeah and a fuel pump haha.
Future plans include flat belly and mini boatsides. Front midarm 3link. Dana70 / 14b.
Ax15 swap with 231/d300. That's all to come over the next few months.
My carnage from RenoFest and fuel pump put me way behind schedule.
Current specs
Engine Stuff
thor cowl intake
99 intake
tube exhaust header
stock cat
Front end
3.5" re springs
RE 1600 trackbar
No Sway Bar
2" Wheel Spacer
Dana 30
stock 4.10 gears
Stock brakes
chevy brake lines
RE Solid Lowers
Rear end
Explorer 8.8
Stock Disks
stock 4.10 gears
1.5" wheel spacers
extended bumpstops
Body
JCR gas tank skid
Stock Eccos Wheels
