craiso
- Northwest Missouri
My beloved 1991 XJ with 380,000+ original miles has become a donor due to a recent roll-over. I understand that most of the work will be a direct swap into my 1998 XJ Sport 2 Door, 2WD. I plan on using the front and rear differentials, transfer case, and both drive shafts from the '91. I am not clear on how the speed sensor on the transfer case will be integrated in to the '98, or if it is even needed. And then there is the 4WD indicator switch on the transfer case. I can see there is a light on the instrument panel, so is there a known method to make it work as well? I have read a few similar build threads. They concentrate on adding the 4WD and usually a lift, but not much information on how to get the required electrical components working. Looking forward to comments... Thanks
