View Single Post
  #2
Old August 10th, 2017, 21:38
rockclimber's Avatar
rockclimber rockclimber is offline
Associate
Re: Stripped throttle position sensor hole, what to do?
if you can find a slightly larger screw to fit through the TPS, tap it for whatever that size is.
or, fill the hole with JB weld, tighten the current screw the same way you have been until just before it gets loose. Then,
go to a junk yard and get a Throttle body in decent shape, so next time you decide to replace the TPS you just swap it on instead.
[cal]You're an idiot rockclimber.
[StinkyFab]RockClimber is a tool.
