JeepNoob
- Pueblo, Colorado
'89 XJ 4.0, automagic, 4x4, no engine mods. Pulled the throttle body off today to clean it (trying to narrow down a rough idle issue, it needed cleaning anyways.) Pulled it all apart, IAC, TPS sensor, throttle butterfly, shaft, everything, and cleaned it all out with carb and choke cleaner. Put everything back together, cleaned manifold and throttle body surfaces and used a new throttle body gasket. Admittedly, did not use new O-rings on anything. Put new vacuum caps on EGR solenoid and valve. Also put Teflon tape on the threads of the brake booster hose nipple and a screw in the intake manifold (more on that one later.)
Measured 4.88 volts TPS reference voltage and 1 ohm on the sensor ground between it's wire and battery ground. (Kinda had to find the sweet spot with my leads to get that ohm, but I got.) Didn't notice a change in resistance when wiggling/shaking the wiring harness near the valve cover. Adjusted TPS until I got 0.83 volts on the output wire.
Starts without a problem and idles smoother, but it sounds like it's idling high. I don't have a tach I can check the RPM with, but if I had to guess, I'd say at least 1,000 RPM, maybe as high as 1,500 RPM. Checked output voltage, it's still at 0.82. Loosened the screw and moved the TPS around just for the Hell of it, still idles high. I should mention that I broke the bottom TPS screw off while taking everything apart, but for now I'm just running with it. I can get the top screw tight enough that it doesn't affect my voltage readings.
Checked the idle stop screw, it has the tiniest gap between it and the throttle arm, so no problems there. I did notice while cleaning up the throttle body that the throttle plate has slotted holes in it and the tiniest of gaps between it and the body. Should I be worried? Should I try to minimize those gaps by wiggling stuff around? What's the point of the screw below the throttle plate? Should I take the Teflon tape off it and/or replace the O-ring? Sprayed carb and choke cleaner around possible vacuum leak locations while listening to the idle, didn't notice any changes. Anybody have other ideas for finding small vacuum leaks? I'll put a vacuum gauge on it tomorrow and adjust the transmission cable to see if that helps anything. Will probably also do cruiser's sensor ground mix. What else could I be missing?
