- Coshocton, OH
Girlfriend has an 01 F150 with the 4.6ltr Trition in it, and just over 153k. Just did plugs (found out after the fact I should have used Motorcraft instead of Autolites). I need to do the EGR cleaning thing where you pull the intake and clean all the EGR passages, and figure out how to reseal the EGR tube at the manifold. It had a lite miss before the plugs, and I figured new ones was what it needed. However it is still missing after the plug change. I've read the coil on plugs are noted to not be very reliable on these things, and I'm sure one of them is the issue. I've tried to locate which one it is by disconnecting them one at a time with the motor running to try to figure out which one it is, but it seams that no matter which one I unplug you can feel a noticeable change in the miss. Basically it seems to miss worse when I unplug one than what it's already missing. (My thinking is when I unplug the one that is missing there would be no change in the miss.)
So I guess my questions are....
Was my diagnostic methods ignorant, and there's a better way to figure it out.
Should I just replace all the COPs, and if I do what brands are recommended (I see them anywhere from around $70 to $200). I rather spend as little as possible on it cause it not that nice of a truck (puke gold, no options, and IMHO the ugliest body style f series Ford ever made), and she only drives it when she has to.
Anyone have a good idea on how to reseal the EGR tube to the manifold?
