RustysOffroad
- USA
Latest deals are up!!
http://www.rustysoffroad.com/sales-clearance
Rusty's Coils - XJ 6.5" Front
Regular Price: $149.00
Sale Price: $120.00
Rusty's Steering Box Frame Plate – XJ Cherokee - Drivers Side
Regular Price: $89.00
Sale Price: $70.00
Is your Cherokee's unibody broken and now the steering box is about to fall off? This frame plate was designed to help do a proper repair on your XJ.
Laser-cut chassis plates are supplied for the inner and outer chassis rail, along with special sleeves that tie both plates together and provide additional support for the steering gear. The chassis plates and sleeves must be welded to the vehicle's chassis, as a bolt-on design could not possibly provide the same level of integrity and fitment. Therefore, the installation does require welding.
Rusty’s XJ Steering Box Brace is a must after this repair if the vehicle doesn't already have one.
Flow Daddy Headers - Jeep 4.0 ('99-'06) Stainless Steel Headers
Regular Price: $275.00
Sale Price: $240.00
The 4.0L engine found in many Jeeps is great little work-horse that offers plenty of torque for the street and the trail. Now you can get even more out of it by replacing the cheap, crack-prone stock header with a Trail Tested Tough Flow Daddy header! These Stainless Steel units are mandrel bent for maximum flow, which results in more power and torque. The laser cut heavy-gauge flanges provide a precision, leak-free fit and the durability needed for hard core trail use.
IMPORTANT! APPLICABLE FOR FOLLOWING INLINE SIX ONLY:
• Cherokee 4.0L ('00-'01)
• Grand Cherokee 4.0L ('99-'04)
• Wrangler 4.0L ('00-06)
KEY FEATURES:
• Mandrel bent 409 stainless steel for maximum flow and performance
• Laser cut thick flanges for a great fit and wont warp
• Comes complete with gasket, head pipe gasket and hardware
Rusty's Flares - Rusty's XJ Standard Flares - SALE!
$179.00
Flares are $90 each, $179 for a set of two (front or rear) or for a limited time all four for $299! Normally $350 .
Finally - a Cherokee flare that gives you the extra 1.25" coverage needed for those oversized tires as well as larger openings! Unlike other aftermarket flares, Rusty's flares give you the abililty to trim from 2.5"-4" of sheet metal to clear larger tires! If you're simply going for style you can install our flares without trimming the fenders but you may see a bit of the fender under the front portion of the flare.
We have two versions now available: Standard and Flex. The Standard Cut-Out Flares are constructed of urethane plastic and finished in a glossy black finish that can be painted to match the rig's color. The Flex Cut-Out Flares are a more flexible urethane that will bend much more than the standard versions. The Flex Flares have a glossy black finish but are NOT paintable. Either style will work on '84-'01 2-door and 4-door Cherokees. A 12" wide tire on a wheel with 4.5" backspacing will be completely covered with these flares.
The Standard Cut-Out Flares do give a little but they are not as pliable as factory flares. They will take a good deal of abuse but if slammed against a rock, they may break. The Flexible Cut-Out Flares are extremely flexible and can withstand heavy abuse.
This part number is for our Standard Flares. Part number RA-FLR2-XJ is for our Flex Flares.
Sale Price: $120.00
Sale Price: $70.00
Sale Price: $240.00
KEY FEATURES:
$179.00
