lordoeuf
- Vancouver Island
My '99 XJ has this grill which looks like a vent on the back seat door jam. You see it when you open the doors and it is on both rear door jams. The grills are fanned down so that rain water doesn't get into the cavity behind the grill. There are also these rubber flaps behind each grill of the vent panel. What is the purpose of these vents?
If you unscrew the vent, you see a cavety which ultimately leads to the rockers below. Under normal use I don't imagine water getting into this cavity from these vents, but if you cross a deep enough stream, I can see water getting into this cavity from these vents. I was considering sealing up these vents, but wanted to know their purpose first. Thanks!
