ok, i'll try searching too, but just wanted to throw it out there and get some input. Its an 01, but im running a 99 complete setup (distributor, wires, 99+ intake).
On cold starts in the morning it cranks but wont start unless I hold down a little on the gas pedal, if i let off the pedal it dies, but i can let off the pedal after about 20 seconds of running and its fine. it also acts this way on warm starts sometimes, and sometime it starts right up.
Also while driving, twice in the past week on the way to work the volt meter on the dash will spike to 19 and the check gauge light will come on, it only lasts about a minute then goes back to normal. idk if its related to the start ups or not ?
Third, the jeep died the other day on me while on my way home, it had the hesitation startup then after about 5 mins of driving it died in the middle of the road. I got it pushed off to the side then tried to restart and i noticed all the analog gauges were dead, and the odometer read out said "nobus" and the check engine light came on.
so i went and got a spare CPS and swapped it out, when i plugged it in to test it out the gauges worked, so i installed it then went to crank it over and the gauges were dead again, then i disconnected the battery cables, touched them together to reset ECM, reconnected battery and it started right up fine. but i
So, now its still giving me the hesitation at startup, and i still have to press down on the gas pedal to get it started, its the same problem as before so i dont know if the 2nd CPS is bad too or something else is going on.
this has been going on ever since a day or two after the last offroading trip and i did get into some mud, but not too bad and it didn't get into the engine bay.
any suggestions ?, maybe i'll try a brand new CPS, but i think maybe a different sensor is bad ?
and shouldn't the 2nd CPS have plugged in and worked fine without having to disconnect and reset the ECM ?
Thanks
KP
Thanks
KP
