cherowagon
- portland, or
ok, i have the factory s4 sanden compressor with the four bolts on top of it.
i want to use another sanden as my oba compressor, but it has v-drive pulleys.
now, i know i can use brackets and adjusters from a volvo that came with the sanden to mount, but i will have to make a small bracket to mount to the top of my fac ac unit because the four bolts are on top.
now then. my question is about the setup and yes i searched.
i will need one of these pulleys to adapt v-drive to serpentine.
http://www.kilbyenterprises.com/pulleys.htm
but i know i will not have enough room to mount the compressor next to the other w/o the battery getting in the way. i have read that you guys have moved the battery to the airbox location and just used a conical air filter. but where do you place the air filter? does anyone have a pic of the entire engine bay with this set up? i have only found close ups of the actual mounting of the compressors side by side. how have you guys changed your batteries and air intakes?
