rkates
- indianapolis in
Set of d44 axles.
Early to mid 80's waggy front axle. 5.13 gears, Detroit locker, stock pass shaft, g2 chromo inner and outer drivers. Warn premium lockouts. Chevy small spindle/ flat top knuckles with arms, brakes. Ford hubs and rotors making it 5x5.5 bolt pattern. Solid diff cover. The axle is set up for a 3 link. Comes complete with inverted t steering. Made with 1 1/2 dom and 3/4" ruff stuff rod ends.(replaced rod ends couple months ago. Also has home built track bar using 7/8 ruff stuff rod ends.(have new set haven't installed yet), the frame side bracket comes with it. Made to mount in stock Cherokee location.
Trying not to forget anything to help with questions. Sorry it's so long winded.
The rear axle is an Xj 44 5.13 gears, Detroit locker. Superior evolution shafts drilled for 5x5.5 bolt pattern. Explorer disc brake convertion, u-bolt eliminators, high clearance shock mounts. Also mounts on top of spring mounts if you want to go that route. Undercover fab truss with the diff cover that ties into it.
Not wanting to separate unless I find a buyer for both. Looking for 2000 for complete set up ready to bolt in. Let me know if you have any questions or want to see something. Don't have any pics but will post some tomarrow
