Cherokee Part out...
VAhasnoWAVES
Lake City, Mi
pulling the jeep into the garage tomorrow to start stripping it... so i am listing the things i am getting rid of. pictures will come as i pull them. prices are OBO.
LOCATED IN STERLING HEIGHTS, MI.
CONTACT ME (WALT) AT 757 646 5173
$750 Ford 9": big bearing housing. custom TMR style UBEs, shaved, grizzly locker, 4.56s, chevy calipers, dodge rotors.
https://scontent-ord1-1.xx.fbcdn.ne...=6cdbfb116d5db8c68ceb8318ba2360af&oe=56AA4976
https://scontent-ord1-1.xx.fbcdn.ne...=fbd05f212c52ee5a69cd39b0a3a6712b&oe=566B198A
https://scontent-ord1-1.xx.fbcdn.ne...=fc165df4a3afd36fe7839d71c44a5165&oe=56A84BD7
$150 Custom Manual Crossmember: built as a stock replacement for a 4.0/AX15, so it will drop an auto trans roughly 3/4". 1/4" plate, center rib, bullet proof. unlike picture, has surface rust... i never painted it.
https://scontent-ord1-1.xx.fbcdn.ne...=0c23779f931f04fb8527e1541e83be65&oe=56683BC0
https://scontent-ord1-1.xx.fbcdn.ne...=6ae9bdd842439163db29edafcbc6f9b7&oe=569CA2D0
https://scontent-ord1-1.xx.fbcdn.ne...=debdd98257f579b418579a282d549320&oe=565D7E71
$200 Rubicon Express Control Arms: came with my superflex kit. rubber bushings were replaced once. bushings and spherical bearings should be checked before running.
$100 Rough Country Control Arm Drop Brackets: Have braces and all hardware. I replaced all hardware with new stuff when i got the brackets.
$200 Rubicon Express Track Bar, Double Sheer Bracket, and Brace: bushing needs to be replaced. heim is good, replaced the RE heim with one from RuffStuff.
$75 D30 Riddler Diff Cover and Lube Locker: some of the hardware has kissed rocks, can still get a socket on them all.
$100 D30 Aussie Locker: unknown condition at this point. will double check tolerance and inspect teeth before selling.
$50 XJ Drag Link and ZJ Tie Rod: brand new... complete knuckle to knuckle to pitman arm.
$FREE.99 D30 housing: 3.55 gears. open diff. passenger side UCA bracing and mini skids. get it out of here.
