mhead
- Encinitas, CA
Hi All,
My 1992 XJ 4.0 4 door 4X4 with auto tranny has a factory fuel pump which has "BOSH 9580810019" stamped on it. A Google search for this number brings back Amazon and Summit as possible suppliers. The pictures at these sites show the correct pump. Searches for this number here on return two threads mentioning this pump.
There are two rubber caps, one at each end of the pump, that are used to install this pump into the next assembly which is the wiring harness, fuel float, and associated tubes.
My rubber caps are old and stiff. They broke when I removed the old pump.
Does anyone know a part number for these rubber caps or some source where they can be obtained as new parts?
Thanks!
Mike
Thanks!
Mike
