Talyn
- Radford, Communistwealth of Virginia
If the cowl induction tube is plastic I wouldn't put the head shield on it. If its metal it would be a good idea. You can get a lace up sock type deal to go over the intake tube.
It is getting really hot and goes to safe mode! I don't know what else might be. it is working almost perfect but when i am driiving for over 25 km it starts acting like half of the injectors don't work.
Sounds like you may want to try and get it relocated into the cabin. I have mine mounted under the hood and don't have any issues, but it's up near the top corner. I also have a poor man's cowl hood/lift kit so it does see some air flow. I did have to silicone the harness however to prevent it from shorting out every time I took it to the wash.
A pretty long way. I added over 0.5 meter onto mine.
