bigalpha
Moderator
- Tucson, AZ
My AC doesn't work and the efan doesn't work.
When the AC is selected in the cabin, the compressor didn't start and the efan doesn't turn on.
I can jump the relay for the AC and the compressor will turn on. It looks like there's refrigerant in the system, because I think I can see some cycling through the little window, but the air never gets cold and the lines in the engine bay also don't get cold. There is no continuity at the connector to the low pressure switch.
When I jump the relay for the efan, it will turn on, but does not turn on otherwise. It stays off even if the coolant sensor (at the tstat) is unplugged.
I jumped the low pressure switch and the e fan didn't come on, but I'm unsure if that's diagnostic or not.
The only other thing is the Jeep isn't running at 14+ volts; at the battery, I measure about 13.8V. unsure if that matters, either.
I know that low refrigerant won't allow the compressor to kick on, but is there another place to check that, if failed, could mess with the AC and the fan?
