Infidel_XJ
NAXJA Member #1065
- Afghanistan & TX
There’s a slight chance my divorce is gonna go south and among other reasons… I MAY have to let her go…… So I’m putting this out as a feeler. Here’s a description. Almost everything is less than 1.5 years and 5000 miles. The gears, lockers, steering, tires, and some others tuff is virtually brand new. It has new paint and the body is pretty much flawless. It comes with a new 4x6 Utility trailer that has been sprung over, set up with wheel spacers, and has matching Baja Claws. There has been a ton of money out into this recently. Asking 7500
The Jeep is a 96 Country. Odometer reads 138k and change but it had a motor swap before I bought it. Runs great and well…. Most everything ales has been replaced
6” of lift:
- Rubicon Express extended upper CAs
- Rubicon Express extended lower CAs with RE Super-Flex joints
- Kevin’s Offroad HD Track Bar/Drop bracket
- Rubicon Express entended front and rear stainless steel brakelines
- Rockkrawler 4.5 lift coils with pucks
- Rockkrawler 4.5 leaf packs with shackles
- Rubicon Express CA Drop Brackets and RE Braces
- OffRoadOnly U-Turn Steering conversion… brand new
- Tera-Flex sway bar disconnects
- Pro-Comp shocks
- Extended bumpstops
Drivetrain:
- Rubicon Express Hack and Tap Slip Yoke Eliminator
- Rubicon Express CV driveshaft
- Rusty’s T-Case crossmember with incorporated drop
- Novak Adapters shifter conversion
- Un-installed Rusty’s motor mounts
Axles:
- Dana 30 HP front with brand new 4.56 gears (Yukon) Powertrax No-Slip. Rockcrusher HD diff cover. Upgraded u-joints. Aluminum axle seals. Skidrow control arm skidplates.
- Ford 8.8 with brand new 4.56 gears (Yukon) and Powertrax No-Slip and disc brakes. Relocated axle high shock mounts. BlueTorch Fab HD diff cover.
Wheels & Tires:
- MT Baja Radial Claws 33x12.50x15.
- Black Rockcrawler wheels
- Matching spare is brand new
- The two on the trailer are 33s as well
Bumpers/Armor:
- Appalachian Offroad front bumper with winch mount. .
- Mile Marker PE8000 mounted recessed into the front grille
- Tomken hooks under the front bumper
- Kevin’s Offroad Rockrails
- Detours USA Rear bumper with integrated wrap around armor and tire carrier
- Performance Metal Works rocker armor
- Slid Row CA skids
- Uninstalled Rusty transfer case skid
- D rings on rear bumper and front bumper D ring insert
Misc.:
- On board CO2 tank
- Fire Extenguisher
- First Aid kit
- Big ass tub of spare parts joints, locker parts, axle parts, straps, etc...
- Spare full shafts and joints
- 3 Core Radiator and hi-flow thermostat
- Hi-Lift jack and custom Formatt rear seat mount
- CB radio and Firestick antenna... the antenna is new and was relocated to the tire carrier today
- Vent holes cut into hood
- Optima red top battery
- Husky floor liners in the front, rear, and cargo area
- Hunsaker bucket seats
- Trimmed front and rear fenders
- Rear shock hoop mounted inside the rear cargo area. Allows you to run long travel shocks without sacrificing droop
- Relocated rear shock mounts to the top of the axle
- K&N cone air filter
- Clear front lights
- Front and rear Rock lights
- Flowmaster exhaust
- New Sylvania white headlights
- TJ side view mirrors
- Fresh white paint with roof rails removed and the holes filled in…. perfect exterior ready for you to beat up on.
Ben 305-519-8736cell is on 24/7 and I work nights. Jeep is in Maryland.
6” of lift:
- Pro-Comp shocks
Drivetrain:
Axles:
Wheels & Tires:
Bumpers/Armor:
- Slid Row CA skids
Misc.:
- On board CO2 tank
- Fire Extenguisher
- First Aid kit
