- Hartsville, South Carolina
So the mj project had the typical tilt column issues. It finally failed completely and would not trigger the starter. Key cylinder was just turning loose. So I decided to tear into it and tighten the bolts on the back.
Pulled the steering wheel.
Pulled the plastic cover by releasing the tabs.
I hate that damn plate and clip.... got it off....
Moved that thing....
Turn signal switch was next.
Then the lock cylinder and cover bolts.
Removed the tilt spring and the pivot pins to this point.
The odd shaped piece will nto come out and the top of the column will not come off to give me access to the damn bolts. What am I missing? I think this column is toast. Is there an option besides trying to find another MJ column? Any help would be great!
Glenn "Frustrated Ghost" Fulmer!
