36 weights to balance a tire?
jeeperguy21
Syracuse, UT
Hi all. Was doing some work on my XJ and I noticed that one of my tires was just plastered with 1/4 oz weights on the inside of the rim. I have 32 weights on one side and 4 on the opposite side in the wheel. I've had these tires for a year or so, and they've been great (35" BFG KM3's), but the number of weights has me scratching my head.
From what I have read, it's not normal to have this many weights as it might be a defective tire or even a wheel that's not perfectly shaped. I got these tires from Discount Tire and will have them offer their opinion, but am wondering if anyone else has had a similar issue with a tire and what the reason was for all of the weights. For reference, I've been running these wheels since 2005 and this is my 3rd set of tires on these wheels.
I'm curious if the tire shop can test the balance of the wheel itself w/o a tire to make sure it's not the issue. Thoughts?
A 35" tire should take about 10-16oz to balance. Industry standard is not more than 1% of total mounted wheel/tire assembly weight.
You would think the tire shop who installed your tires would have mentioned the exxess amount of wheel weights it took to balance them.
When I read Discount Tire, I shook my head in a disgusted manner. What a bunch of mouth breathing Morons.
Find an locally owned independent tire shop with a Hunter Road Force Balance machine and some technicians that are not still wet behind the ears from their Momma bathing them. The Road Force machine and a skilled operator can determine is there is a problem with the tire or the rim, and then balance it correctly. My local tire shop has technicians that have been there for 15 years or more, I never ever saw the same people twice at Discount Tire before I stopped going there.
Nine ounces out of near 80 lbs tire and rim weight. dont sweat it. Sure they could have used less weight, but then you'd complain about the vibration. I got a good deal of weight on some of mine, and I have lighter 33" MT tires.
The rims are often made well balanced, bent rims can be a big issue however, that will throw it all out of wack. often you can see rim damage, such as signs of a hard hit.
Gee Tim, could you tell us what you really think?
:laugh:
I am on the same page. Between Discount Tire and Costco I no longer let any of those clueless bastages touch my vehicle. I put the vehicle up on jackstands and take them the wheels and old tires.
I have yet to find a shop with any two employees who have two synapses to rub together.
I had walmart balance my tires I'd already put on once. It took multiple hours and it shook like a paint shaker after. Redid them at a buddy's place with his balancer and it was smooth after that.
I ended up buying my own mount and balance machines and just do them myself every time now. I only paid... I think 550 for both used on marketplace/craigslist. At around 100 a mount/balance job, I've nearly paid for them already. It's nice to be able to do it on my own schedule, if 2AM is when I have time to swap my tires, I can, and I always know they were perfectly balanced every time.
How can you cross thread a lug nut and bust my center cap and not notice, and NO I do not want anybody to install a new cabin filter or windshield wipers. :banghead:
My local tire shop hand torques each lug nut, and they charge less.
Im on with the mouth breathing morons but ill lump every tire shop in that category not just discount.
Id have them nock that tire lose and turn the rim 180 then start over on the balance machine.
I just had a set of near unbalancable street tires on my pickup. Brand new 295x60x20s.
Shit tons of weight nearly 2 hole days of my waisted time. And more and more weights each time they spun them.
Ended up with zero confidence in theyre tire balancing. Switched to maxis razr mt. Did beads thats how much confidence i had in them.
Truck is butter smooth now
Retourqed my lug nuts when i got home. Most were close to spec a few were 50ish lbs shy.
The Hunter Road Force machine will advise the operator that break down and a tire spin is necessary.
The locally owned independent shop I go to, the shop manger and several of the crew have been at this same shop for +20 years, and I see of them on the 4x4 trails too.
Adjust tire position on wheel and retest before adding weights? Makes sense, offset imbalance in the tire and wheel themselves as much as possible before adding weights to fine tune.
