98NWCherokee
- Portland, OR
So I'm in the same boat as a lot of fellow XJers trying to get my AC to work correctly during the summer. I have a 98 Limited and I have partial operation with my system. I first suspected the low pressure switch after posting here initially and getting some great advice. I replaced the low pressure switch but the problem persists. The compressor only cycles on briefly and then stops. When it is working the AC blows COLD so I know its working somewhat. I'm not getting any water below the Jeep so then I suspected a plugged drain. I pulled the drain hose off the firewall and carefully inserted a coat hanger to see if there was an obstruction. Nothing came out and the hose was clean. My next idea was to try topping off the freon. I bought a bottle from my auto parts store with a built in gauge. At first I couldn't get the system to take freon because the compressure wouldn't cycle. I waited about 4 hours and tried again and the compressor cycled on great. The system took the entire bottle, but the gauge shows good. Now, the system works about 70% of the time instead of 30% so I'm on the right track. My question is this: Do I continue adding freon or do I bite the bullet and take it somewhere? I don't want to overfill the system and I assume the gauge on the freon kit is accurate. Should I try another bottle ($26)? And if the system requires that much freon should I be suspect of a leak? The bottle was 18oz.
Thanks for your time and any thoughts you might have
Thanks for your time?
