CypukaT
- Saint-Petersburg, Russia
1997 XJ PCM diagram required
Good day, Sirs!
I have a problem with my wifes mostly stock (just +2inch) jeep XJ 1997.
Check engine says p0202 means that the PCM detected a fault in the injector or the wiring to the injector
I replaced wires between second injector and ASD and 2nd injector and pin15 in PCM white plug (the middle one). Nothing changed.
After that I've opened PCM. Well from pin 15 and 2nd injecotrs mosfet there is no signal. For other injectors signal from pin to mosfet is ok. Made straight wire from pin 15 to mosfet, injector started to work, but still I have p0202 error. So I need to find problem between pin15 and 2nd injectors mosfet and I need PCM Diagram.....can't google it anywhere.
So can please anyone help me with PCM Diagram pdf?
Pics of PCM if needed:
https://yadi.sk/i/AXyWgT9syG9D9
https://yadi.sk/i/i-aGTeeXyG9Dd
https://yadi.sk/i/QTr6_xkMyG9Dm
Thanks in advance! And best regards from #RussianJeepFamily =)
Good day, Sirs!
