Old April 24th, 2009, 22:25
stevedrums stevedrums is offline
'89 fuel pump wire colour
puttin in a kill switch. i cut open the harness underneath the driver's side kick panel. wondering what colour the wire is for the fuel pump.
i checked this
http://www.projectxj.com/mods/kill.switch.htm
but colours don't match up
thanks in advance.
Old April 24th, 2009, 23:07
joe_peters joe_peters is offline
Re: '89 fuel pump wire colour
Nice write up.
My 1990 FSM shows AT THE PUMP--RD (red) positive, VT (violet) gauge sender, BK (black) ground.
Changes to:
PK (pink) positive, TN (tan) gauge sender, and the ground doesn't matter.
So, in summary, if the 89 is like the 90 you want the pink wire.
Old April 24th, 2009, 23:28
thanks for the quick reply. hope your xj has something similar 'cuz it sounds pretty nice from your sig
Old April 24th, 2009, 23:32
That is one of the things on my "to do" list, and I think I'll "to do" it tomorrow.
Buddy of mine up in Eugene, Oregon says there have been a number of lifted XJs stolen there in the last few weeks.
Good luck.
Old April 25th, 2009, 11:01
Originally Posted by joe_peters View Post
Nice write up.
Changes to:
hmm pink wire didn't kill pump. time to do some more searching
Old April 25th, 2009, 11:30
Ok, my Haynes (which I consider less reliable) shows a four cylinder 86-90 with a orange to pink/white to orange wire.
Haynes for six cylinder 87-90 with a orange to pink/black to orange.
Back to 90 FSM--you don't have an MJ do you? Shows a RD to RD to RD all the way.
Old April 25th, 2009, 11:35
Cobalt Cobalt is offline
My '89 has an orange wire as the 12v lead.
Old April 25th, 2009, 11:47
So it is orange at the B pillar? Is your 89 a four or six?
Old April 25th, 2009, 13:53
89 is 6 cyl
Old April 25th, 2009, 14:39
i cut the orange wire and it still idled for a min or so...
Old April 25th, 2009, 14:51
Residual pressure in the system.
Did it die?
Old April 25th, 2009, 14:52
no i waited and waited
Old April 25th, 2009, 15:02
cut the pink/black one and it didn't even have the pressure to start. now i just need to wire the switch. THANKS!!!!!!
Old April 25th, 2009, 15:32
I LOVE IT!
There is a S--t load of wires in there.
My fuel pump positive IS the 14 gauge pink with black stripe. The only other large gauge wire I see in mine is brown with white stripe. As far as I can see all the other wires are of 18 gauge or thinner size.
Old April 25th, 2009, 15:34
Hey, glad you got it!
Make sure you make clean and tight connections--big fan of soldering here--and heat shrink tubing or tape it up tight.
Good luck.
BTW--is that Lethbridge Canada or California?
Which wire for fuel-pump kill switch...? XpedientJ OEM Tech Discussion 31 May 6th, 2010 17:41
advice on fuel pump sending unit wire. outlander OEM Tech Discussion 0 June 5th, 2008 12:07
stupid fuel pump... (or ghetto fuel pump repair) philip_g OEM Tech Discussion 27 July 19th, 2006 02:44
Fuel Pump Relay/Fuel Pump wire in the cab? FRAM OEM Tech Discussion 3 February 6th, 2006 15:11
Overhead Wire colour question cykaaro Modified Tech Discussion 0 March 6th, 2005 18:15
Copyright ©2000 - 2017, vBulletin Solutions, Inc.
