Old December 18th, 2008, 14:30
mr2guy7 mr2guy7 is offline
engine light flashing-wont start
Ok, here's the story... I was litterally 20' from my driveway when the check engine light started flashing, so i parked and shut it off and opened up my manual to see what it meant. I tried to start it back up to see if it would stop flashing and it won't start, it cranks though... also white smoke comes from the exhaust when i try to start it. So, does anyone know what it could be?
Old December 18th, 2008, 14:36
bcmaxx's Avatar
bcmaxx bcmaxx is offline
Re: engine light flashing-wont start
what year, was it running rough previous to the flashing? does the exhaust smell like raw fuel? pull a plug or two see if its black or wet. Usually a flashing engine lamp means its really dumping fuel into it. bad plug(s) ,wire (s) ,cap/rotor or bad front 02 sensor. Its likely flooded
Old December 18th, 2008, 15:14
its an 01 but i was driving fine right up till the light came on and it started missing... i had changed the plugs about 2 months ago... the car only has 67000 miles on it- could the coil pack rail thing be bad already? Also the exhaust does smell like fuel
Old December 18th, 2008, 15:29
bcmaxx's Avatar
I'd make sure you have healthy spark on all cylinders before anything else. Nothing sucks more than throwing parts at it you dont need. I'm not familiar with the 01, so hopefully someone else has some tips for you. I do have mitchell on demand if you need any info,etc.
Old December 18th, 2008, 15:57
Tim_MN's Avatar
Tim_MN Tim_MN is offline
Freakish Hand Strength
A flashing check engine light means that whatever is wrong has the potential to destroy your catalytic converter, and the Jeep should not be driven. Stop by a parts store and rent the CEL trouble code reader. The trouble codes you download will put you on the right path for diagnosing the problem.
Originally Posted by bimmerjeeper
Blanket caught in the rear liftgate latch. Now I can't open.
Check Engine Light Flashing....Injector circuit open? penberth OEM Tech Discussion 26 February 13th, 2016 01:03
Put my engine in.. now wont start centralmax OEM Tech Discussion 9 February 7th, 2007 22:01
new engine wont start rehab Modified Tech Discussion 8 July 20th, 2006 23:15
Engine Wont Start xjrrrdx OEM Tech Discussion 20 July 6th, 2005 12:35
Engine wont start... Stuck Homieguy OEM Tech Discussion 26 April 19th, 2005 19:32
Copyright ©2000 - 2017, vBulletin Solutions, Inc.
