- Williams AZ
Got a bunch of stuff for sale here. Trying to clean up a little.
Wheel spacers, 1", 5x4.5" bolt pattern. Come with Nuts. $40
315/75/16 Yokohama Geolander AT's. Equivalent to a 35x12.5 Very aggressive for an AT, but also very quiet if you still DD your rig. 4 tires on black steel rock crawler wheels. Wheels are 15x8 with about 4 inches Back space. Same exact tire/rim combo I have on my Jeep right now. They are very good in almost all situations, never lost a bead with the eight inch wide rims either, even aired down to 7-8psi. 2 tires and wheels are BRAND NEW, 2 have VERY limited use on my trailer. I would consider tread to be 98% on those two. All four are mounted and ready to go.
$600.
4x6 trailer for cargo/motorcycles. Old, but very useable. Permanent plates. 31 inch tires, spare included. Jeep bolt pattern, so you can run whatever you have laying around. Portal style axle....LOTS of ground clearence. Pintle tongue. Front and rear gates are removeable to make loading and carrying motorcycles easier. Been all over bigbear and to MOAB a few years back. Tongue height is about right for 3-4 inches of lift and 31-33 inch tires. Has three tire racks up front for motorcycle hauling.
$750
$600.
$750
