Old September 3rd, 2008, 21:54
mh01xj mh01xj is offline
Death Wobble?
I have a 2001 xj. I put the 2" lift kit from skyjacker on it. Everything was fine for the first 10K miles. Now when I go between 45-50mph, the whole jeep shakes like crazy. If I speed up past 50 or slow down below 45 it is fine. Can only 2" of lift cause the driveshaft to be at too steep of an angle? I didn't get an alignment afterward, could this have something to do with it? Would a tcase drop slove this? Please let me know. Thanks!
Old September 3rd, 2008, 22:14
JNickel101's Avatar
JNickel101 JNickel101 is offline
Re: Death Wobble?
um....go get an alignment and let us know how that goes for you. even the smallest amount of lift can toe you in too much. But after 10k miles, it might have worn your tires unevenly....had those rotated/balanced recently?
Old September 3rd, 2008, 22:22
magimerlin's Avatar
magimerlin magimerlin is offline
Re: Death Wobble?
First off, welcome to .
Well you admit to not getting an alignment done yet so not to be caption obvious but get that done first then let us know. You shouldn't need a tc drop but every Jeep is different. Check the whole front end out. Then when you run outta ideas go over it again just in case.
I will say it before anyone else does. This topic has been covered many many times. Yes every one has a little bit different set up but the areas to check all end up being the same, usually. Do not forget about the Search button, it has solved a many of issues I have had so that I had no need to post up the Question after I got done reading the other threads. Some people are just anal about telling everyone to search and not helping right away.
But get that alignment done and have them make sure that everything is tight under there, then let us know what happens. enjoy.....
Old September 3rd, 2008, 22:30
JJacobs JJacobs is offline
Re: Death Wobble?
The lift toed it in at least a quarter inch. Your Jeep apparently took it in stride, until the tires started cupping resulting in balance issues. Hopefully just a rotate/ balance/ align will fix it for you.
Death Chatter.....not death wobble twoksl2 OEM Tech Discussion 18 March 10th, 2008 17:57
maybe the death wobble TheBlueSub Modified Tech Discussion 12 May 23rd, 2006 20:27
I Have The End All Fix For Death Wobble littlexj1 Modified Tech Discussion 24 March 11th, 2005 12:12
Wobble of Death ang31-0f-d347h Modified Tech Discussion 4 March 5th, 2005 19:16
Death Wobble live24wheel Modified Tech Discussion 7 March 1st, 2005 15:53
