stewie
I'm looking for a little input on this one. If I can get this project done before the Fall Fling, great. If not, thats fine too.
I found a set of hood vents off of a Chevy Lumina Z34 something or another. They are all metal, have larger openings than the Lebaron vents and also have plastic drain pans.
Here are some pics:
Just placed on the hood
Mocked up under the hood to show fitment
And with the drip pans mocked up. They would have to be trimmed to clear the hood supports. That would put the drip pans draining over approximatly the AC compressor and the power steering pump.
And a little comparrison between that and the LeBarron vents.
The pro's that I see are that the vents are made of metal (as apposed to plastic with the LeBarron vents), drain pans with a mesh between them and the vent, I like the styleing, and I havent seen it done on an XJ before. The cons I see are the drain pans may restrict airflow, pans may drip onto the serp belt, and I havent seen it done on an XJ before.
Opinions?...
Here are some pics:
Opinions?...
