Old August 22nd, 2008, 13:30
dan302492's Avatar
dan302492 dan302492 is offline
odd noise when letting off gas
been trying to figure out what this was for a while. while driving usually a bit over 30 and higher it makes an odd noise coming from what sounds to be my transfercase and then when i get back on the throttle it makes a small clunk noise then its gone. sorry for the ill discription. could this be a overly stretched drive chain making that noise after it picks up the slack or the output shaft bearing(does not leak though)??? I know its not the driveline u-joints because i have checked them multiple times.
Old August 22nd, 2008, 13:32
WaXJ_Skier's Avatar
WaXJ_Skier WaXJ_Skier is offline
Re: odd noise when letting off gas
I would still lean towards driveshaft ujoints.
Shirts: Because if You stop wearing shirts, You'll probably stop wearing pants, and nobody wants that
2000 limited upcountry
94 YJ 4.0 AX15 2" lift D30/D35 ARB/Detroit 3.73
Old August 22nd, 2008, 13:49
dan302492's Avatar
they would have to be very well worn though to make the clunk noise when i get back on the gas though
Old August 22nd, 2008, 15:47
poorboy_616's Avatar
poorboy_616 poorboy_616 is offline
Tranny mount on the crossmember.....
Old August 22nd, 2008, 15:48
housemaster0630's Avatar
housemaster0630 housemaster0630 is offline
the same thing happens to mine
it does sound like it is comming from the transfer case
but mine happens when i come to a complete stop and start up again
its like the rear of the jeep is kept up in the air a bit and then suddenly dropped
like the slip yolk isnt doing its job correctly
Old August 22nd, 2008, 15:58
UNCC_99XJ's Avatar
UNCC_99XJ UNCC_99XJ is offline
Twisted Up
In your case, all you need to do it take the driveshaft off and grease the slip yoke....it's a fairly common issue....drove mine for a couple years doing that....always thought it was the brakes maybe sticking a little bit. I read about it on here and had the DS off changing a ujoint, slapped some grease on the output shaft and put the DS back on and the "thump" went away.
-Timbo - SEC Treasurer
-'99 Sport, RE 4.5" and a few other things
-'13 Performance Blue Ford Focus ST. DD & Race Car.
Old August 22nd, 2008, 16:40
Deadman 94 xj Deadman 94 xj is offline
if you're talking about what I think you're talking about, it seems like some sort of gear backlash in the transmission.
When I'm on the throttle and let off, it kind of clunks back in when I get back on the throttle. I can hear the down shift through the exhaust when it does this.
Mine has done this since it was stock. If it's the same thing, it's not the transfer case because I'm running a different case and it still does it.
All in all I think it's prety cool lol.
Mines a 96 with 110 on the clock and shifts perfectly FWIW, my old 94 didn't do this.
Old August 22nd, 2008, 16:41
X2 on the slip yoke.
Old August 22nd, 2008, 16:44
dan302492's Avatar
i guess ill give that a try and see if the sound dissapears
Old August 22nd, 2008, 16:47
marcoleo's Avatar
marcoleo marcoleo is offline
if U have already checked driveshaft & u-joint check your rear diff, I'd similar problem on the diesel one, the pinion nut was a bit loose so no preload and some play on the pinion, I was luky to discover it before destroy my 4.11.....
Old August 22nd, 2008, 17:13
cherokee chuck cherokee chuck is offline
Unexpectedly, my mystery clunk I've since I dropped my t/c might be solved. Gracias people. I guess it's time for an sye. Dropping the case cured the vibes but I've had clunk with the drop feeling ever since. I changed the mounts, retorqued u-bolts, shackles, etc. It only happens when taking off in a straight line at brisk acceleration & only occasionally so I've living with it. I'm replacing my springs in the near future & figured that would cure it but I'm going to try grease on the yoke tonight!
Letting Some Steam Off XJoshua Non-Tech / Off Topic 36 December 6th, 2007 18:40
Letting Jeep Sit BSD OEM Tech Discussion 5 February 5th, 2006 09:33
Just letting off some steam theslacker Non-Tech / Off Topic 0 March 26th, 2005 22:16
Thank you for letting me serve Andy Steiner SoCal Chapter 4 March 3rd, 2005 12:33
Copyright ©2000 - 2017, vBulletin Solutions, Inc.
