northwestxj
NAXJA Member #1283
- washington
Just got done changing the ball joints and am trying to figure out what to do with the split ring (adjustment sleeve) in the bottom of the knuckle. I have heard mixed things about it. Some say that it should be set to .2 inches of depth (as per FSM)...is this .2 inches DOWN from the top of the knuckle, or .2 inches UP from the bottom of the knuckle?
Others say that it is for adjustment purposes and I should first tighten the top nut then tighten the split ring tight, then tighten the bottom nut. I have tried both ways (first being .2 inches up from the bottom of the knuckle) and as I start getting things tight the knuckle gets ridiculously hard to move back and forth...what's wrong? What sequence do I tighten the nuts and what do I do with the split ring? Doesnt seem right that the knuckle should be hard to turn like that....please help, need to get my jeep going for tomorrow. Thanks.
