TALLRAM
- LUBBOCK TEXAS
I am trying to make one out of two XJ Jeeps, I have been told that the NP231 from my 1993 4.0 aw4 will bolt up to my 1995 4cyl 5-spd, I believe since the 5-spd is stock it is AX-15 which means they should both be 23 spline. My question is will the NP231 from the auto bolt up to the 5-spd assuming the splines are the same? Is the bolt pattern the same? What is the 6 or 8 point bolt socket size the is used at the top of the aw4 to 4.0? Metric no doubt.
