| Street and Performance A forum to discuss modifications related to street XJs and performance tweaking. |
Thread Tools | Display Modes |
my AUSI 300mm front brake retro/ Teraflex rear disc conversion
Hey Guys, I'm new to posting on
, but I've been on Jeepforum for well over a year. I plan on moving some of my more informative posts here over the next little while because I'm tired of the JF atmosphere (long story short: I can't deal with their moderators). Those comments aside,here are some pics of my Brake install. I had all the parts installed last summer. The front kit is a 12" slotted rotor with a two piston caliper. The kit came with SS brake lines, AND I had the front rotors cryo treated (more on that later). You can get more info on the kit at www.go.jeep-xj.info/HowtoFordBAdiscs1.htm. Along with the brakes, I also had some addco F+R swaybars installed along with the brakes. here's what the calipers looked like out-of-the-box ![]() ![]() ![]() a look at the rotors. the teraflex rotos like similar in diameter, but they have a much smaller contact surface compared to the front rotors. You caan also see the front rotors are cryo- treated... one year later and the front rotors look brand newwhile the rear teraflex rotors are rusted (the hats rusted in the first week) ![]() ![]() ![]() painted the teraflex calipers ![]() ![]()
#2
Re: my AUSI 300mm front brake retro/ Teraflex rear disc conversion
last look at everything before the install
![]() ![]() off to the shop ![]() knuckles getting trimmed ![]() ![]() installed behind my stock 16s... can't even tell what I'm running
#3
Looks great man. I've been meaning to ask you how much you paid for all that?
#4
I got in on a groupbuy put together by SilverXJ, so we saved a heck of cash
on shipping fees, and they threw in the powdercoating for free.... I believe the kit set me back $530 + shipping + cryo treatment. . |
#5
I wonder if those match anything US made. Like crown vic or Explorer sport trac or Mustang.... If you can fab a bracket in AU to fit up a Ford part number then we should be able to do the same thing here without having to import the parts.... And opening the way to a junk yard swap...
I think the next time I'm at a pick and pull I'm going to yank some front calipers and rotors off some 5 on 4.5 Fords and Dodges with dual piston calipers, and bigger rotors. the XJ/MJ/YJ/TJ world is wayf***ingoverdue for a reasonable big brake upgrade. |
#6
To my understanding, my kit uses a twin piston Ford Falcon caliper along with the matching 300mm rotors (made by PBR). The big advantage is that you can retain your stock master cylinder because the new caliper displaces the same volume of my old-stock caliper (2 smaller pistons opposed to one larger piston).
I know my brake upgrade was costly, but I can honestly say it was worth its weight in gold. I wish there were cheaper alternatives, but sadly there aren't (unless you're mechanically savvy). Personally, I think some of the XJ/MJ/TJ guys should get together to harass powerslot to make a Power Slot Plus kit for our application. I wouldn't be as good my 2 piston set-up, but it would make for one hell of an improvement over our stock brakes. . |
#7
for us guys that wheel frequently in mud/dirt will the slotted rotors hold all the drime and wear the pads?
im looking for a better highway braking with 33's and that kit seems about the same as a wj conversion perhaps a lil easier. |
#8
You could also do the Vanco brake kit, basically the same thing.. Or the WJ upgrade.. The aus kit is close to the sport trac stuff.. All you need is a little ambition and some fab skills... Nice install and realy purdy red calipers... Next time loose the sloted rotors.. they just shred your pads sooner.
#9
those are mustang 99-04 calipers and most likely mustang rotors. I would just really like to get my hands on some of those caliper brackets! wonder if they are sold separately?
#11
Eh I don't think they are exactly the same. I know the hub register is different... I have a 98 Cobra and have tried it. Urban Yan, Can you tell us the hole to hole dimension on the caliper mounts? The stang is 132mm. Also can you find the hub/rotor offset (back of rotor to back of hat)?
#12
the rotor may not work. and the AUSI kit shows a bracket for the caliper, but the caliper sure looks like a S197 braking system. ie 99-04 style brakes
#13
S197 = 2005-up stangs. 94-04 = SN95 99-04 = New Edge SN95.
#14
They aren't sold separately. I asked.
#15
| Currently Active Users Viewing This Thread: 1 (0 members and 1 guests) | |
| Thread Tools | |
| Display Modes | |
| Thread | Thread Starter | Forum | Replies | Last Post |
| Teraflex D44 rear disc brakes conversion | casm | Modified Tech Discussion | 4 | 03-11-2007 17:20 |
| Front d44 disc brake conversion | ttocsnekia | Modified Tech Discussion | 1 | 11-29-2006 22:53 |
| Teraflex d44 disc brake conversion kit | HeadCase | Modified Tech Discussion | 6 | 08-25-2005 15:13 |
| Teraflex (Ford Explorer) Rear Disc Brake Conversion Backspacing | Thayer | Modified Tech Discussion | 21 | 08-06-2005 08:27 |
| Rear disc brake conversion- brake lines | bknudtsen | Modified Tech Discussion | 5 | 09-02-2004 10:37 |
