Go Back   NAXJA Forums -::- North American XJ Association > NAXJA's Technical Forums > Modified Tech Discussion
Register FAQ Users List Calendar Mark Forums Read
HOME Member FAQ Sponsor Info Rules Donate Bylaws Store Members Chat E-Mail
Old 08-13-2007
Gravesdiggerxj's Avatar
Gravesdiggerxj Gravesdiggerxj is offline
Used Parts Pimp
Talking My 44/9" full width cherokee build
(Dial up: shoot your computer)
So I got tired of being careful with the throttle and worrying about my weaker stock axles and all the crap I've broken so far.... that, and I popped my spider gears over the weekend of the 4th of August.
So here comes the axle swaps :headbanger: . I bought the whole underhalf of a Ford 76' F-150 custom on the 5th.
I spent most of last week cleaning up the rear axle and old wheels that I'm going to run on the street.. 32" Kelly Safaris. (35" mtr's offroad)
This'll be kinda slow because I'm getting Hitched the 21st of September so all the $$$$ is going to that
I'll keep a running Tally of what stuff costs
Brake drums $28.50x2= $57
Brake lines and u-joints $20
Stainless braided brake line extension $fiftey-free$ (thanks Brad)
Brake shoes (Raysbestos 5year) $12
Wheels Cylinders (Rays) $12x2 = $24
Moper leaf spring perches (six states) $10
Paint and Primer $50+
Brake Fluid $4.99
Gear lube $12 (you need to change yours anyways)
Grinding wheels, flapper discs, welding wire (whatever)
Spidertrax wheel adapters (#WHS-004 for the front for now) $82
total $253
(sorry about the crappy pics... I killed the digi so I get to use the phone)
Monday-Friday
halfway
primered
the wheels
before
bare metal
after
Saturday
grabbed some of Spidertrax anodized wheel adapters for the front to fix the width and convert from 5x4.5" to 5x5.5" lug pattern
#WHS-004
looks funny on little wheels in front
Ran up to my bud's shop in Bountiful to start
Brakes (thanks Brad)
End of Saturday
Old 08-13-2007
Used Parts Pimp
Talking Re: My 44/9" full width cherokee build
Sunday
Ran up to Sill's in Layton for breakfast if you get a chance get a sweet roll. $3. Bigger than my whole plate...sheetcake sized
Fabbed some shock mounts
And yanked the Axle
Primed and painted with new third member
More later......
[IMG]file:///C:/DOCUME%7E1/SERVIC%7E1/LOCALS%7E1/Temp/moz-screenshot-2.jpg[/IMG][IMG]file:///C:/DOCUME%7E1/SERVIC%7E1/LOCALS%7E1/Temp/moz-screenshot-3.jpg[/IMG]
Old 08-14-2007
Used Parts Pimp
Exclamation Re: My 44/9" full width cherokee build
Updated pictures with the axle under the Jeep!
I ran her up to 85mph down the point of the mountain and no problems. It tracks perfectly straight.
Looks almost factory.
I reused the factory brakeline "T" and it worked perfectly.
You can see that we placed the Shock mounts just below the centerline of the axle tube to keep them off the rocks. (ignore the crusty shocks... salt corrosion sucks, they're only a year old)
I'm also loving my smooth street tires. They are so much better for daily driving and my wheelin' tires will last longer too.
Old 08-14-2007
BRIANHO13's Avatar
BRIANHO13 BRIANHO13 is offline
<- Yum Chocolate
the lift blocks are a bad idea.
http://www.hdoffroadengineering.com/
H.D. Offroad Engineering LLC
Order your shackle relocation brackets and frame stiffeners now.
Old 08-14-2007
barillms's Avatar
barillms barillms is offline
Lift blocks are FINE. As long as they're steel and no higher than 3".
Tack weld them in place to the leaf perch on the axle.
You may experience some axle wrap, other than that... they are fine unless you are some kind of extreme rock crawler. Most people aren't rock crawlers.
Old 08-15-2007
ahm's Avatar
ahm ahm is offline
Nice work, How much wider is it compared to stock?
Old 08-15-2007
uncc civilengineer's Avatar
uncc civilengineer uncc civilengineer is offline
I agree... lift blocks are fine on trucks, etc. that are crusing around the mall.. otherwise get rid of them and make up the lift w/ springs/shackles (if economically possible) they're just not safe.
Another option: Buy/Make some U-bolt eliminators that are nice and wide...
The axle wrap is what's going to leave you sitting on the trail with a rear axle flush with your transfer case after the lift block has fallen out...
Old 08-15-2007
RyanM's Avatar
RyanM RyanM is offline
Great work on the axle swap, but man, those leaf springs are very 'tired'
You'll be fine mall crawling.
Old 08-15-2007
BRIANHO13's Avatar
<- Yum Chocolate
Or the axle wrap can eat ujoints, like mine did until I added a traction bar and I only have a 1" block.
But like said above you should be fine at the mall.
Old 08-16-2007
Used Parts Pimp
New shocks today! Rancho RS9116 adjustables, approx 13" compressed 24" extended. Take off's (3 mo's old and free) from some kid who needed a bigger lift
Thanks, I'd guess 2in wider than stock per side 66" WMS to WMS, but my rims on my street tires have 5.5" of backspacing and the tires are 1" narrower, so it's hard to tell.
Thanks. Ya my springs are hashed! I toasted those springs (4.5") with axle wrap (35" mtr's) before the 2" blocks (they're steel btw). I picked up a toyota leaf pack and hopefully this weekend I'll build a pack that will last more than a year.... and get rid of those blocks....\
BRIANHO13: do you have any pics of your traction bar?
Also forgot to add.... thanks to XJ_Ranger, baseballneal86 and Fatwreck (Brian) for the inspiration and answering my questions.
Old 08-16-2007
RyanM's Avatar
Does your EBrake work?
Old 08-16-2007
Used Parts Pimp
Yes perfectly. I was able to adapt the stock cables. They are identical to Ford's in everyway except for length
Old 08-16-2007
xcm's Avatar
xcm xcm is offline
darwin award runner up
::looks around::
wheres the posts about the 44?
Old 08-17-2007
Used Parts Pimp
Originally Posted by xcm
::looks around::
This is a build thread... read the first post, it's in production.
Don't worry.... progress pics soon
Old 08-17-2007
fuzzydog fuzzydog is offline
lookin good! hope you keep this thread goin with the rest of the build. I considered a full width 9" and d44 when I started my build but went with an explorer 8.8 - you are making me regret my decision
Build up of my XJ going to full width BRUISER Modified Tech Discussion 36 11-05-2009 12:52
Full Width HP44/9" Build-Up baseballneal86 Modified Tech Discussion 73 12-15-2008 18:44
full width 9" and 44 are in (pics) fatwreck Modified Tech Discussion 18 10-24-2007 20:25
Running hp44/9" full width axles on 37x12.50x15 tires--How much lift/b.s. on 8" rims Big Red Modified Tech Discussion 10 01-27-2005 15:36
Powered by vBulletin® Version 3.8.3
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
NAXJA and NAXJA logo's Copyright NAXJA. All content/images Copyright NAXJA 1999-2009
