I will be redoing my floors and raising my fuel tank so it doesn't hang below the frame rails. I want to add as much ground clearance after the axle(D44) as possible.
My rear fenders are cut extensively and I should be able to have 6" of uptravel with 6" of down travel. 33" tires are what I have now, but will probably be replaced with 35" tires.
I'm working on a rear coil set-up for about 5" of lift. I plan on using XJ or ZJ front coils mounted outboard/notched into the frame. I'm planing on using a 3 link with a trackbar. The upper link will be centered over the rear diff.
For the trackbar the plan is a drivers side frame mount and a passenger side axle mount. This should help with exhaust routing. The rear shocks will be mounted behind the axle and outboard of the frame rails.
I will be plating the entire uniframe and adding the needed bracing for support. A full rollcage is also in the planned(JeepSpeed style).
Your opinions and input is welcome and if you can't post on this forum PM me. I can post your input myself...
