| Advanced Fabrication and Engineering If you are worried about your project still being called an XJ or MJ, this is the place for you. If you haven't ever had a slag burn or know the smell of burning flesh, tread lightly. |
Thread Tools | Display Modes |
3 link front...
I have been laying under the heep lately trying to figure out what to do. I was thinking of a 3 link and did some searching but did not find much here. What happened to the URF I think it was 3 link build up thread? I was measuring where I could put the lower nad upper links and discovered that with my 203/205 setup I could run lower links about 40" long. Do I want this? Is longer better or should I shoot for a 30" or so lower link. The plan was puting the upper 3rd link on the passanger side. I know I need about 8"-9" of seperation at the axle end but what about the frame end? Can they be closer or do they need a lot of seperation too? This is all new to me and the plan was to do some reading on what everyone has. Unfortunately I cannot seem to find any of the threads. Any build threads you guys have would be greatly appreciated. Maybe we can get them in one thread with the right title for easeyer searching.
"...I need to wheel to be rejuvenated to fix things to wheel. It's a vicious cycle, but I love it." Rick Pewe Ed: Petersons 4 Wheel and Off Road member since 3/05/2001Bored? Click me! |
#2
Re: 3 link front...
#3
Re: 3 link front...
My radius arms are 40" long and work fine. Just try to mount them up nice and high at the frame because they'll stick back so far.
Or you could just "ramp" the mounts, some people seem happy with that method.
Spotters lead the way! My green junk. I don't own any leaf springs. G & G Offroad and Auto Repair...the shop I use!
#4
Re: 3 link front...
#5
Re: 3 link front...
Here's how mine ended up.
I've been extremely happy with it so far. Very predictable handling on road & off, and it has much less unloading during climbs than my old radius arm setup did. Converging the links towards the frame side (having less separation there vs. the axle) is usually desirable; mine's got about an inch and a half less at the frame. I can adjust it about an inch either way: but so far I haven't had a reason to want to try and tweak it.
'94 XJ, 4.6 stroker, NV4500, NP231-D300, D60, 14ff, 38.5s. |
#6
Re: 3 link front...
what do you hope to accomplish with a 3 link?
what dont you like about your current front suspention?
Nothing in Moderation . . .. . . . .... . . . . . . . . . . . . . . 35's and under Cal Rocs competitor #91 . . . . . . . . . . . . . . . . . . . . The Ride Racing |
#7
Re: 3 link front...
#8
Re: 3 link front...
Here is a link to Jes's photo albums. Tech and Tech2 have a number of pics of his and crashes hidden long arm 3 links.
http://www.fototime.com/ftweb/bin/ft.dll/home?userid={0641A5A9-DB40-46BE-9569-B61D5BC8B151}&tio=0 Here is a link to a thread of my hidden 3 link long arm build: http://www.naxja.org/forum/showthrea...=Hidden+3+link A number of the pic links are not working though. I'll post up some current links to my stuff below: Frame mods. http://share.shutterfly.com/action/w...=8IbtGzVo3bMvi Long arm prep. http://share.shutterfly.com/action/w...=8IbtGzVo3bMtq 4wd shifter mods. http://share.shutterfly.com/action/w...=8IbtGzVo3bMvA Long Arm part 1 http://share.shutterfly.com/action/w...=8IbtGzVo3bMuE Long Arm part 2 http://share.shutterfly.com/action/w...=8IbtGzVo3bMum Jeff |
#9
Re: 3 link front...
This is the exact reason why I'm now building longs arms as well! Vettboy gave me some good advise (thanks) & have the 3rd link setup done on the pass side(well mocked up) & cycles sweet, only 1 deg change in caster @ full bump-droop. May need a little tweek here & there but it's close enough for goverment work.. Now i have to remove the wishbone & add a tracbar & build mounts on the Waggy 44. My XJ has a Vortec V6 with NP241 T-case so I have other problems getting everything tucked up inside the frame rails, dang tcase hangs 4 inches below the rails with no room to go up.. Fun project can't wait to get back on the road though.
[quote=Ghost]I actually learned why longer link are better at Tellico this year. I was climbing a rock and the front looked like it was being pushed under the jeep and the front was rising just not the axle. |
#10
Re: 3 link front...
It doesn't have to be complicated, or difficult to build, to be effective. It just needs to be strong. The arm angles are more important than the length, so let the length be whatever it works out to as you decide the best (easiest) place for the mounts. There are 3 links out there that work well with arms in the 20" range on up. The amount of axle seperation at the frame isn't very important, just make it so the geometry comes out good. A basic goal could be to make the upper arm as close to level as possible and the lowers with the least amount of angle and yet have good ground clearance on the mounts.
As one more example of length, the front arms on my XJ buggy 3 link are about 25" on the lowers and 22" on the upper......and it's been climbing pretty much everything.
Richard Gauthier.........2008 and 2009 King of the Hammers finisher Team . 2010 King of the Hammers Team GenRight Offroad Thanks to , J.E. Reel Drivelines, Maxxis Tires, CTM Racing, Bishop-Buehl Racing Engines, BajaHID.com, MasterPull
#11
Re: 3 link front...
#12
Re: 3 link front...
mock it up & run it thru a full cycle (full bump-droop) & you will see why a lot shorter upper link in no good,The pinion & caster are crazy. I made the mistake myself so TAKE YOUR TIME & DO YOUR homework
. Use the 3 link calc above to run numbers & Again take your time & do it right the first time cause you will be sorry if you don't . I'm no expert on 3 links but have learned a ton just doing research & asking more questions than I should of.Quote:
#13
Re: 3 link front...
Not too much shorter on the upper, or you risk excessive castor change. If the upper is level, you can handle it being a little shorter, since the arc of movement will be minimized by it being level. You could make the upper in the best place for you, then make the lowers accordingly. The only negative with too much difference in length between the uppers and lowers is excessive pinion angle change, which can bind the u-joint at the pinion.
#14
Re: 3 link front...
#15
Re: 3 link front...
The positioning of the upper link isn't that crucial. Usually it ends up being pretty far to one side or another due to packaging reasons.
The panhard is what establishes the roll center. Typically you want it as long and flat as possible, but at the same time it needs to be approximately parallel and equal length to the drag link in your steering. The higher you can get the panhard mounts, the more resistant to roll the chassis will be; however there's a point at which it gets too high and can give you some strange reactions to sidehilling etc (you won't have as good an idea when you're approaching the flopover point). Basically it's gonna just be an experiment to find what works best on your rig, however with all the crap you'll have to fit it around in the front of an XJ I'd be surprised if you can get it high enough to be a problem. Goatman's rear panhard on his XJ buggy is probably one of the tallest I've seen and it works well for what he does.
| Currently Active Users Viewing This Thread: 1 (0 members and 1 guests) | |
| Thread Tools | |
| Display Modes | |
| Thread | Thread Starter | Forum | Replies | Last Post |
| Front 4-link brackets? | Gaius | Modified Tech Discussion | 10 | 03-20-2007 22:27 |
| my front 3 link...in progress | gearwhine | Advanced Fabrication and Engineering | 24 | 07-07-2006 21:35 |
| Four link rear/URF three link front shakedown pics | Roxtar | Advanced Fabrication and Engineering | 53 | 11-01-2005 15:41 |
| Trying to set up 3 link front | flexj | Advanced Fabrication and Engineering | 8 | 08-08-2005 07:16 |
| 2 link front end? | sweetjeep | Modified Tech Discussion | 21 | 12-09-2004 11:51 |
