Hmm, RENIX rig! I have been through water up to the doors a few times over the past month, no problems yet.
There is a vent on the transmission case, it has a rubber line that goes up to the back of the engine somewhere. If that rubber line were compromised, water could be a problem.
Back to the RENIX remark:
First, the auto tranny is electronically controlled. Clean the connectors just because. They are located between the starter and heater control valve.
Second, the
Transmission
Control
Unit depends on signal from the
TPS, same as the
Engine
Control
Unit. I can't help but think the TCU is just as vulnerable to ground problems as the ECU. RENIX is notorious for bad grounds causing problems with other engine controls.
I would start with the grounds, make sure they are clean before throwing money at the problem. Twice I have had the notorious high idle show up with all the moisture. I wiggled the TPS wires and extra ground wire that I installed. So far, so good. Here is a pretty extensive thread on the RENIX system, hope it helps.
http://www.naxja.org/forum/showthread.php?t=905849&highlight=renix+files
Or, you could always sign the title over to me. I know of a few teenagers who are coming of age. LOL
Two more things: It's NOT the CPS! Your Jeep will NOT fold like a taco because of this problem!
