Old July 7th, 2007, 16:59
s7tech's Avatar
s7tech s7tech is offline
fuel rail O-ring
I removed my intake manifold and header when i was installing it. The fuel rail supply line o-ring was worn out out. When I start it it leaks. I have been chasing the new o-ring all over the place and can not find one. The jeep dealer says it is discontinued parts and they have no supplier. Any one have any tips. Later Danny
Old July 7th, 2007, 17:07
Hellbent's Avatar
Hellbent Hellbent is offline
Re: fuel rail O-ring
what year, etc.? that should still be available at almost any dealer. post some specs and i'll get you the factory #, you can hit them up with that.
edit: if it's 96 and down it should be 83502745, it's a repair "kit" consisiting of the oring, the plastic spacer rings and the retainer clip.
Old July 7th, 2007, 18:14
scca28 scca28 is offline
I just picked up two yesterday at a Chrysler dealer for my '88 engine swap. They had to order, but had them two days later. And yes, it was part number 1-83502745. About $16 a kit.
Old July 7th, 2007, 18:24
s7tech's Avatar
it is a 1990 cherokee with 4.0l.
Old July 7th, 2007, 20:01
bajacalal bajacalal is offline
At Napa we have a selection of fuel line quick disconnect items including the whole piece that snaps over the nipple and small packs of O-rings, clips, nylon hoses, etc...
Old July 7th, 2007, 20:08
xjtrailrider's Avatar
xjtrailrider xjtrailrider is offline
You can get a set of the fuel injector "O" rings, they come in a package of 13. 2 for each injecter and one for the where the fuel pressure regulater meets the rail. If its the supply line or the return line that is leaking then you can get the "O" ring and the clip on a pre-loaded tool to insert into the lines from the dealer. They are about $12 each
Sorry i do not have the part numbers in front of me but they are still available.
Fuel Rail Silent Modified Tech Discussion 8 March 13th, 2010 13:00
Fuel Injector/Fuel Rail Disassembly Beagles OEM Tech Discussion 9 January 1st, 2008 10:46
Fuel injection hose, in place of fuel rail quick connects 92DripCherokee Modified Tech Discussion 7 December 5th, 2007 12:32
im lost here ..leaking fuel from this thing on the fuel rail VegasAnthony OEM Tech Discussion 11 November 2nd, 2006 11:12
99 XJ Fuel Rail 1999mj Wanted: Private Party Only 1 September 2nd, 2006 14:26
