Old May 8th, 2007, 11:06
Jeepxj94's Avatar
Jeepxj94 Jeepxj94 is offline
Question Electric Fan OverRide Switch
Hey all,
I'm about to install a Trans cooler, thermostatic control valve and trans temp gauge. The Trans Cooler will be mounted on the Eletric Fan side. What I want to do is be able to turn the Electric Fan on whenever I want and when not in that mode have it in normal operation.
Anybody know of any great write ups??
Thanks in Advance!
- Scott
P.S. XJ is a 1994 Country.
Old May 8th, 2007, 12:33
DaffyXJ's Avatar
DaffyXJ DaffyXJ is offline
NAXJA Member #929
Re: Electric Fan OverRide Switch
http://www.naxja.org/forum/showthrea...t=60972&page=3
More than one way to do it.
Old May 8th, 2007, 12:49
Jeepxj94's Avatar
That is for the '97 plus Models!
-Scott
Old May 8th, 2007, 13:43
Gonzo's Avatar
Gonzo Gonzo is offline
Get yourself a two-position on-on switch. You should have three terminals on the back.
Cut the power wire going into the fan,
Terminate the chassis side on the center (unswitched) contact.
Terminate the fan side on one of the other contacts.
Terminate your constant 12V on the remaining contact.
One postion of the switch is now normal, the other is now always on.
You will have to splice in wire, or the switch will be right in the engine bay.
Old May 8th, 2007, 14:05
DaffyXJ's Avatar
NAXJA Member #929
I don't see that there is a difference....
1) tap into the 12 v wire at the electric fan. run 10/12ga wire to a relay, attach to pin 87.
2) Run 10 ga wire from pin 30 to battery.
3) Run ga wire of your choice (say 16/18 ga) from switched 12v source to pin 85 or 86 of relay.
4) Run similiar sized 16/18 ga wire from ground to your new switch, then from switch to the unused 85 or 86.
Done!
When you turn on the switch the relay passes 12V B+ to the fan and it runs. When you turn switch off, fan waits for factory signal path to send 12V to fan and it runs.
Old May 8th, 2007, 14:18
Gonzo's Avatar
Done!
Oh sure take the safe route and use a relay.
Old May 8th, 2007, 15:17
Jeepxj94's Avatar
Sounds like a job I got to do soon! Wait for parts to come in then begin.
Does it matter what switch I use in the interior? Just a 2 position switch is fine right? So I need 10/12 16/18 wire, a relay and a switch to get.
Thanks!!
-Scott
Old May 8th, 2007, 15:54
DaffyXJ's Avatar
NAXJA Member #929
I use red guarded switches, 2 bucks from jc whitney or similiar place.
Old May 8th, 2007, 16:29
Jeepxj94's Avatar
Thanks!
I'll order some up. Nice Interior! I'm liking that.
-Scott
Electric Fan Override reson46 OEM Tech Discussion 14 June 10th, 2009 02:58
Electric Fan + Stock fan override BBeach Wanted: Private Party Only 0 February 10th, 2007 17:34
Electric Fan Override robsewter For Sale: Private Party Only. XJ ITEMS ONLY 9 July 29th, 2006 16:52
xj-armor electric fan override edmaude OEM Tech Discussion 3 February 13th, 2005 23:24
Aux. Electric Fan Override? Kevin Modified Tech Discussion 12 September 9th, 2004 15:38
