Old April 28th, 2007, 00:57
blackdoutxj's Avatar
blackdoutxj blackdoutxj is offline
Question HEAT>>>
just wondering .... today was one hell of a hot day and i come out to see coolant under the jeep and i just changed my waterpump and hoses, and i didnt find drips from there so i assumed it was from my overflow?!
Old April 28th, 2007, 01:18
5-90's Avatar
5-90 5-90 is offline
Re: HEAT>>>
Erm, what year? It's important - as you may recall, there were some small cooling system changes over the years...
Old April 28th, 2007, 05:51
Jeremy89XJ's Avatar
Jeremy89XJ Jeremy89XJ is offline
Re: HEAT>>>
This may sound stupid, but did you remember to tighten the lower rad hose to the pump? I won't go into why this is the first place I would look...
--Jeremy89XJ--
Old April 28th, 2007, 07:27
RichP's Avatar
RichP RichP is offline
Re: HEAT>>>
--Jeremy89XJ--
Whenever I do hoses on the water pump I put a coat of Indian Head gasket cement around the first 2" or so of the inside of the hose, then install. Once you clamp them down the indian head seals it very nicely. I had a 82 S10 2.8L that I replaced the water pump on and it would leak no matter how tight I made the clamp, two quick roundy rounds with the Indian head, back on, clamp and tighten with a 1/4" drive it never leaked again. Also unlike RTV Indian head does not get a death grip on the two surfaces.
Old April 28th, 2007, 08:17
Lew360's Avatar
Lew360 Lew360 is offline
Re: HEAT>>>
Depending on the year, I would look at the heater control valve. I got a replacement from advance auto that leaks unless you have either the heat or vent on. Can't figure it out so I plan to just run straight hose.
Old April 28th, 2007, 09:55
Re: HEAT>>>
its a 2000 and there are no leaks coming fom the new hoses or pump.....and whats the heater control vavle?!
Old April 28th, 2007, 10:06
Lew360's Avatar
Re: HEAT>>>
Never mind you don't have one.
Old April 28th, 2007, 13:05
Blaine B.'s Avatar
Blaine B. Blaine B. is offline
Re: HEAT>>>
Temecula was a beautiful place, FYI...now back on topic
Old April 28th, 2007, 16:50
Re: HEAT>>>
hahah y thanks ya, i loev it, except for the DAM HOT weather lol!
Old April 28th, 2007, 16:52
Blaine B.'s Avatar
Re: HEAT>>>
I was there maybe 6 years ago or so, liked it alot!
I'll take the hot weather compared to the winter we have here in doucheland. < lol
Old April 29th, 2007, 20:32
Re: HEAT>>>
ya i pretty use to it playin football in it but still everyonce and a while get annoyed of it...and the jeep does of course...
Heat maine96xj OEM Tech Discussion 6 November 26th, 2006 21:11
no heat delverde OEM Tech Discussion 3 November 13th, 2006 10:15
no heat? Lavacrawler OEM Tech Discussion 5 December 11th, 2005 20:23
NO heat or at least little heat mark268 OEM Tech Discussion 8 January 26th, 2004 10:45
Copyright ©2000 - 2017, vBulletin Solutions, Inc.
