Say you have a jeep with 4.0, AW4, 3.55 gears, and 235/75R15 tires (right there may be a variable because they may have rated with AX-15 and 215/70R15 for that matter...). At 60mph with the 235's you'll be turning about 700revs/min at the wheel. Therefore its about 1864rpm at the engine. For every 2 turns of the crankshaft, every cylinder will have taken in air (3955cc or about 4.0L). <---Now is it taking in 4.0L or the V.E. x 4.0L? That's my first question. But since the V.E. is just a constant at the exact rpm, I can toss it in later if need be. With the 1864rpm/2 = 932rpm x 3955cc = 3686L/min which is the same as 3686L/mile of Air. To find the mass of air you use the formula M=D/V and find that mass to be 4423.2grams of air per minute assuming 1.2g/L density. Using an air/fuel ratio of 15.5:1, that 4423.2/15.5= 285.37grams of gas per minute. Using wiki's density of gas and the known mass, you find the volume to be 2.5834L gas/minute. But.....thats .6825gallons per minute and therefore 41gallons per hour....which is just a little bit wrong. :huh:
Anyone know where I screwed up and if theres somewhere where V.E. of say 60% is in effect, or that air is only 23% oxygen, or that combustion obviously isn't 100%? And if so, does anyone know how much its off by and why? I'm not sure why I'm doing this but this is what you do when you're bored.
