Old January 22nd, 2007, 21:35
andrew2516's Avatar
andrew2516 andrew2516 is offline
Brake Lines for 8" lift
I've been thinking about going with Crown brake lines...but the longest I can see is 6" over stock...is that enough for 8" and LA's? Anyone have any other suggestions for brake lines?
Old January 22nd, 2007, 22:33
WheelinJR's Avatar
WheelinJR WheelinJR is offline
Re: Brake Lines for 8" lift
dunno if theyre long enough, but you could always go with the JKS lines.
What kind of wheeling are you doing that you need that kinda height?
Old January 22nd, 2007, 23:20
HilltopXJ's Avatar
HilltopXJ HilltopXJ is offline
NAXJA Member #950
http://4wheelparts.com/PDT47646.aspx
You also could try to check around local for someone to make them for you.
Old January 23rd, 2007, 00:09
whitetrashxj's Avatar
whitetrashxj whitetrashxj is offline
i got 20" front braided brake lines from skyjacker and got a rear 24" braided line from them too, costed me 240 bucks canadian.
Old January 23rd, 2007, 08:31
steelmen's Avatar
steelmen steelmen is offline
M.O.R.E. has the longest brake lines i have ever seen (26")
Old January 23rd, 2007, 10:43
baseballneal86's Avatar
baseballneal86 baseballneal86 is offline
The rear soft brakeline for a 94-01 Dodge Ram 1500 is 8" longer than stock if I remember correctly. I'm running it with a 4" lift and there is way more slack than I can use.
Old January 23rd, 2007, 11:12
andrew2516's Avatar
I'm thinking 6" longer than stock should be fine. I know my stock lines were fine at 3" of lift and now at 5" they get pretty tight.
So i think 6" longer than stock with an 8" lift will hopefully be fine.
Old January 23rd, 2007, 11:35
WheelinJR's Avatar
probably a good cheap option.
personally I would say if you are upgrading go to a stainless line. its going to be more durable, plus it doesnt flex as much, err expand under pressure like rubber will.
That will create a more solid pedal feel and better braking performance overall. That mixed with using DOT5 brake fluid will drastically change the way your brakes feel. The DOT5 brake fluid is great, it just needs changed more often.
I would think that your brainwork is good on that. If you figure it, your stock did ok at 3 inches, add 6 more, should be ok to 9 inches.
Old January 23rd, 2007, 12:04
andrew2516's Avatar
Thanks for your help guys. I figured it would be fine...I always try to double check with some other people though before I put money into stuff.
Old January 23rd, 2007, 13:16
xj4life's Avatar
xj4life xj4life is offline
if you want to get some nice flexible stainless lines give these guys a call. they are just around the corner from my house and have never done me wrong.
http://inlinetube.com/
Old January 23rd, 2007, 13:55
Power5 Power5 is offline
What is involved with getting that onto a cherokee? Is it a straight swap?
Old January 23rd, 2007, 14:48
It was a direct swap on my `95. The only difference besides the length is the angle at which the Dodge T-block is radiused to sit on the axle. You can see in the pic that the radius for the axle tube runs at a 45* angle to the brake line. On the XJ brake line, the radius runs perpendicular.
To correct this I simply ground a small radius into the brass T-block of the dodge brake line.
Hopefully this is clear enough.
Brake lines for 5-6" of lift? Double Down Modified Tech Discussion 16 November 4th, 2005 07:55
Brake lines & 8" of lift slvr98svt Modified Tech Discussion 0 August 22nd, 2005 18:53
extended brake lines for 3" lift w/ABS Codhead Modified Tech Discussion 5 November 4th, 2004 11:34
5" lift and need new brake lines.. jjvande Modified Tech Discussion 3 January 1st, 2004 14:05
Extended Brake Lines for RRO 2" BB 96country Modified Tech Discussion 2 June 6th, 2003 06:20
Copyright ©2000 - 2017, vBulletin Solutions, Inc.
