So there has been lots of discusion about a 242 HD SYE. Just so everyone is on the same page. There is no heavy duty slip yoke eliminator conversion for the 242. 231 TCs have various HD SYEs from Advanced Adapters, PORC, and others that replace the stock output shaft with a bigger stronger one. My solution is not a HD output shaft SYE.
I looked at Tom Woods. A lot of money for a glorified hack n tap. Although I'm sure it's a good job, I didn't want to take the time and money to do this. There is the RE hack n tap. I have heard of loosening, and then wobbling. (from Tom Woods) There is another company that cuts and taps the shaft, but then heat treats the shaft. $$$ The only option at the present time is a hack n tap.
I was steered to this site http://www.driveshaftsuperstore.com/drive_shaft_SYE.htm
After talking to them, decided to give it a try. A RE HnT can be found for $80, so for $20 more, why not? I wanted it for these reasons
1. You can bolt a front drive shaft directly to it.
2. I machined it to fit tight on shaft (more later)
3. Stronger than a RE HnT
4. No adapter or anything else needed
This is what I started with.
As you can see it is plenty long. I cut it to the length I needed. Wanted 1 inch of spline contact. There is space at the yoke end with no splines. About .25". So I had to leave 1.25 of splines on the output shaft. Next I did this.
You can see by the cut off piece that the yoke shaft is splined the entire length. The diameter of the splined part on the output shaft is 1.172". after the necked down part, the shoulder at the TC seal is 1.178". I had a friend machine the inside to fit tightly on the shoulder all the way to the seal. This is what gives the strength. More shaft engagement (still just 1" of spline contact) to eliminate wobbeling. You can see my cut and tapped shaft here
The shoulder part is .7" so plenty of contact. From there, the yoke slips right on and it's bolted like any other HnT.
From there, I just bolted up a front shaft from an 4.0 auto. I wanted a good shaft, so I went to a parts yard and paid $70 for a 99. Later on, there was a 98 in my u-pull yard. Late models are real rare in my u-pull yard. I got the front shaft for $15. So for the $99 yoke, and $85 for shafts, I now have a SYE, a 99 front shaft on my rear, and a 98 shaft for a spare. I'm real happy with the results. I had a friend machine it, but it isn't complicated. If I had to take it to a machine shop, it couldn't cost that much, $20-$25 bucks??? Feel free to pipe up if you have any idea. There you go. What do you think???
