Old March 20th, 2006, 06:49
MoparManiac's Avatar
MoparManiac MoparManiac is offline
Question Rebuild or Replace?
'91 2-dr 4.0L AW4 NP231 d30/8.25 192k miles
I bought this XJ for $600 back in Aug '05 after I sold my '85 Dodge Ram mainly as a better commuter into Boston for school (I live on the south shore ). I do take it off-road about 2-3 times a month even though it is my DD. About 2-3 months ago it developed a knock that we've just decided to call piston slap since we've no clue what else it could be (intermittent knock, no loose flexplate bolts or cracks, runs really well with good power, etc).
I haven't had to throw too much money at it and I have yet to have any major issues with it. Transmission shifts like new, 4wd works great, no rear end or front end noises to be hugely concerned about (just a popping in the front end - trac bar?). I also had plans to run a Rustys 3" lift and get skids, tow hooks, etc.
Now my main question comes...this summer I'll be working alot and I have been thinking about it after talking with my dad, should I continue throwing money at this thing and rebuild the engine and whatnot when it comes time, or should I save money for a newer XJ and sell this one or keep for parts? It does have a lot of miles on it and it is 15 years old, but nothing major has happened yet (knock on wood). I guess I'm really just looking for advice?
Old March 20th, 2006, 07:00
87manche's Avatar
87manche 87manche is offline
Re: Rebuild or Replace?
what shape is the body in? Have you pulled the carpet to make sure the floorboards are rusting out? Any fatigue cracking by the steering box?
If the body's in good shape then you may look at buying a newer wrecked XJ for cheap and swapping drivetrains.
If it's got cancer then keep it for parts, and find a newer one to build.
RIP Ugly Truck
Old March 20th, 2006, 07:35
It does have a fist sized hole under the drivers side floorboard with some cancer on the rockers. The previous owner put some body putty over the rockers so I have yet to see the actual shape of them.
Sell, rebuild or replace? grahamtwatson OEM Tech Discussion 9 November 27th, 2005 12:06
99 AW4 to replace 94 AW4 Dano Modified Tech Discussion 2 July 12th, 2004 14:05
rebuild/replace AW4? rj454 OEM Tech Discussion 1 March 3rd, 2004 20:58
Replace or Rebuild? old88xj Modified Tech Discussion 2 August 2nd, 2003 20:33
engine problems, replace? rebuild? stroke? DJ6624 Modified Tech Discussion 8 June 16th, 2003 04:47
