Jeffro600
- Cheyenne, Wy
Finished up with my RE 4.5 lift and corrected the Death Wobble issues i had( a SERIOUS toe in problem) and now im having a problem with the 4WD. Heres the problem...ive got a lockright in the front and its ratcheting when going in a straight line while in 4WD. You drive along in 2WD, no noise as usual...pop it in 4WD and the ratcheting comes on STRONG and increaces with speed...even when going in a straight line while under power. When you put it back into 2WD, the ratcheting continues and wont stop unless you make a HARD left turn....wont stop with a hard right. Im thinking its a problem with one of the hubs not disengaging or engaging when put into 4WD....anyone else got any idears??? This is for a 93 Cherokee...AX-15 NP231.
Mind you, this all worked fine before the lift...
