Old July 11th, 2003, 05:29
jeep_cj8 jeep_cj8 is offline
belt tensioner
Besides a belt getting loose, what are other symptons of a belt tensioner going bad? How expensive are they and are they easy to change? Is there any maintenance I can do to maybe get it working more properly?
Rob Bubala
Old July 11th, 2003, 09:47
XJ_MAC's Avatar
XJ_MAC XJ_MAC is offline
NAXJA Member #184
What year XJ?
Old July 11th, 2003, 09:48
97
Old July 11th, 2003, 09:54
AZ Jeff's Avatar
AZ Jeff AZ Jeff is offline
What year XJ are you talking about? Various years used different tensioners.
I general, the only "failure mode" for most tensioners is the bearing in the center of the idler pulley will begin to fail. That will be accompanied by squeaking or squealing.
Another test for idlers is to remove the belt from the idler and spin the pulley by hand. Growling or grinding or roughness is a sure sign of imminent bearing failure.
Belt tension on Serpentine belt? Planetcat OEM Tech Discussion 36 July 10th, 2009 00:58
belt pops off? acuxj OEM Tech Discussion 5 November 10th, 2003 16:41
serpentine belt jaros44 OEM Tech Discussion 5 November 6th, 2003 12:15
York belt path, pic vintagespeed Modified Tech Discussion 4 September 1st, 2003 23:21
Serpentine belt on a 97+ RichP OEM Tech Discussion 2 August 31st, 2003 14:33
