- Cheyenne, WY
OK so it's been doing the random high idle thing for awile. Start the Jeep it idles at 2K+ rpms for sometimes as long as a couple minutes then slowly returns to normal. Started with the previous owner. He changed the MAP sensor and IAC motor. I now have it and it's been something I want to fix but it hasn't done it in awhile so you forget about fixing it... So I install a bored TB and spacer and transfer the IAC and TPS to the new TB and figure I should set the TPS to the correct adjustment. Find the procedure in the FSM, get the meter out and adjust the TPS to spec.
Bad idea! Input voltage is 4.72vdc, the manual says if you don't have 5.0vdc input voltage then you sent the output voltage to 82% of the input or in my case 3.87vdc. Start the Jeep and it idles at 3800rpm and will not come down. Hmmmm... So out with the meter again and start experimenting with various TPS output voltage settings, increasing voltage in .10vdc increments. The only way to get it to idle (below 3000 rpm) is to set the output voltage to 4.35vdc or higher. OK so the TPS is "bad". Off to NAPA get a new one, install it, adjust it to spec and it idles at 3000 rpm. UGH! I skip the experiment phase and go back to 4.35vdc output voltage and it idles normal.
But wait there's more, At the high TPS output voltage it has a surge at idle and a very noticeable bog when you zip the throttle. So being the tinkering kind of guy I am I set the TPS to factory spec with the engine running (although the FSM says not to do that) and the idle smoothes out and the throttle response is crisp. Shut it off, and on the restart it goes back to the 3000 rpm idle. Pissed off now, back to NAPA and get a CPS, the only sensor left that I can think of and change that. No effect on the idle.
The only way to get it to idle is with a high output voltage adjustment on the TPS.
My assumptions are as follows:
1) the TPS decreases in output voltage as throttle position is increased. This leads me to believe that with the high TPS voltage setting I am running very lean at idle. Which makes sense as the idle is surging and it has a bog of idle.
My questions are:
1) is there a pressure port on the fuel rail to test fuel pressure? if so what is spec on it?
2) anybody know how the RENIX computer actually works? can you still get one?
3) what other inputs to the ECM have effect on fuel delivery? Temp sendor and knock? Knock is more a function of timing though...
Background info on this Jeep. 1990 model. 198,000 miles, tired but still runs well (other than this idle thing)
Got any ideas?
Bob
My questions are:
Got any ideas?
Bob
