- Bakersfield, CA
Posted from a PM:
i had a couple questions i was hoping you could help me with. my xj currently has 3" and 31s, but i would like to go about 6 or so with 33s. rather than go with the RE drop brackets or a long arm kit that will eat up my clearence i would like to do like a mid-arm setup. problem is i dont have a welder. however, i know a guy that has a private shop that could probably weld up some new mounts for me a little farther back on the frame.
basically, what im trying to figure out is if there is a lower control arm that i could buy that is about the right length and would work with the mounts a little farther back. while doing some searching i found an old thread where you said currie "j" arms will work. i tried searching for those a little bit on the web and didnt have a whole lot of luck. all i found really found was their site: http://www.currieenterprises.com/cestore/categories.aspx?id=993
and about half to three-quarters down there is some J arms. are these what you were talking about, do i want the J bend? i didnt think so, but im not sure.
also, what im trying to figure out is if i need to weld on new mounts for the uppers, and also what arms to go with for them. can i leave the mounts where there at and use some say RE adjustable uppers.
ultimately, im trying to find a good setup that will flex well and not just rush into a long arm, or drop brackets.
what do you think?
FYI-my xj has and will keep the d30 up front.
Jake
what do you think?
Jake
